MP6632 Programming
I’m currently trying to use the MP6632 in a project and want to start by working with the “EV6632-R-00A” evaluation board. As a first step, I need to set HLOGIC to “high/low logic input”, but I don’t see any way to program the MP6632.
In this post, MP6632 OTP/Resistor settings - Motor Drivers/Sensors - Monolithic Power Systems’ Technical Forum, it’s mentioned that this can be done using the “MPS Virtual Bench Pro 4 GUI”. However, the chip doesn’t appear in the list of options in the software. Even scanning doesn’t detect it.
What is the correct software for programming the MP6632, and where can I find it? What is the proper communication device for this purpose?
Additionally, I can’t figure out how to program the chip later during operation via I2C. Where can I find documentation for the interface? What should the data frames look like for reading and writing the registers
Hello Wema,
Thank you for reaching out. I believe things have since changed for support on virtualbench pro 4.0. Please reach out here for further support: MPS NOW Technical Support - Contact
