Hi, I have a big problem with this regulator.
I have inrush current at startup. in this case the regulator does not start working true, but if I turn the power off and on fast (before capacitors discharge) it is start working true.
do you have any solution or idea?
thank you.
Hi @mokhtari.bas,
If you’re comfortable sharing your schematic publicly you can post here or you can contact us using MPS NOW Technical Support form: MPS NOW Technical Support - Contact and we can help resolve your issue.
Saurabh
