Hi All,
Could any one give me a link to download the “eMotion Virtual Bench Software”? The original link to the software is no longer available.
I just purchased a EVKT-MSM957188-36, but I find no where I can download the software to use it. If you have a copy, would you mind send it to killeyzib@gmail.com? Thank you!
Hi killeyzib,
Thanks for your question.
I’m checking with the eMotion team, I will get back to you shortly.
Cindy
Hi killeyzib,
All eMotion products have been moved to a new website: http://www.monolithicmotion.com/.
You can download the MotionLAB software here: https://www.monolithicmotion.com/motors/support/motion-software.html
Cindy
Hi Cindy,
Thank you so much for the info. It now works with the software.
Hope the following notes are useful for future users:
1. The software set slave address default to "1". You may need to set the slave address to 0 for the first run, otherwise you may encounter "communication failure" message.
2. I used the "MMS757188-36-R1-1" design file to work with the EVKT-MSM957188-36.
3. The cables that come with the evaluation kit become loose after plug in and out for several times. I ended up open up the "communication kit" and soldered the wire (5V, GND, A and B) directly to the PCB board.
