Writing to HR1211 failed
I am unable to write the parameters from the GUI to the chip in any way. Previously, I tried to import data using the “export parameter” button, but it didn’t work. Now, I am using the “program parameter” to import data, but it prompts an error.
Apologies for the delay. Thank you for posting on the MPS Technical Forum.
A couple questions:
  • Are you using the HR1211 evaluation board?
  • Is the GUI able to connect to the part? Or are you just seeing issues with writing parameters?
Allison
