Hi there, i want to using MP2908A to creat a 50V to 24V application, and i noticed that it has maximum duty cycle at 99.5%.
Accroding to the datasheet`s output voltage formula to calulated the FB resistor R10 should be 348kohm.
But using the simulation model to set 50VIN @ 24VOUT that FB resistors can not be verified correctly.
So I would like to check this with the FAE.
Thank you guys.
