The /WD_DIS pin in MPQ6411 behavior after disable
The /WD_DIS pin in MPQ6411 behavior after disable is not clear in datasheet, as after enable and then disable the WDG the WDG chip will start from the beginning T0(timeout) or the closed window or from disable has ended?
Hi Mohammed,
/WD_Dis pin only enable/disable the output of WDO. Internal window counting and trigger operation ignores /WD_Dis.
Let me know if you have any more questions.
Yash Shah
