I am using Virtual Bench Pro and can read the voltage and current, but the temperature is not being read correctly.
The temperature always shows 80°C. Ofcourse the device is not hot.
What should I check?
Hello @hidekazu.inaba.t43,
Welcome to MPS forums. I see you’re unable to read the temperature of MPM54322. Which version of Virtual Bench pro are you using to communicate with the chip?
When I displayed the version in help, it was “Version:4.0.63.1928”.
I found the reason.
MPM54322’s temperature register only had 3 bits.
The lowest value;000 meant 80°C.
So it was right.
