Doubt that the MP2410 will do it, it features short circuit protection, you need a part that will pump the full current into a short. They may not even know what you are speaking of, perhaps share a snippet of your proposed schematic.
thank you for the reply! that shows an external FET but it doesn’t appear to be a shunt FET, which is driven by PWM signal, connected in parallel with the LEDs (so essentially shorting them when active).
