Requirement: IC with Charging + USB Dual Role + Data Support
n our application, we require an IC that can handle power charging, USB Dual Role Port (DRP) functionality (source and sink), and also support USB data transfer between the device and host. We came across the MP2722, but from the documentation it seems that the USB data lines (D+/D–) are routed directly through the IC, and we are not sure if it supports seamless data communication along with PD/charging. Could you please confirm this and suggest if MP2722 is suitable for our use case, or recommend an alternative IC that meets our requirement of charging + DRP + USB data transfer?
Thanks
Regards
Rajkumar
I will email you to discuss the details. Thanks!
Fox
Hi Fox,
Hope you are doing good,
Am not get any update,Could you please confirm this and suggest if MP2722 is suitable for our use case, or recommend an alternative IC that meets our requirement of charging + DRP + USB data transfer?
Thanks
Regards
Rajkumar.
