Hello everyone,
I am currently trying to program the non-volatile memory of a MPM54304 PMIC with an Arduino Uno Rev. 03. I am using the MPM54304 demo board.
I can change the outputs, pull enable low or high and set everything else. The only problem I have is setting the MTP program bit to 1. When I do this nothing happens. The VCC voltage does not change and nothing is programmed. Also the page number does not change.
I suspect it has to do with the MTP password, so the programming bit is still protected. I could not find any information on what the password is. Could you give me the information about the password?
Thank you and kind regards.
Kirsty
