Sir/Ma’am,
I need to develop a power supply for instrumentation purpose with following characteristics:
Input Voltage: 70 - 270 VAC
Output Voltage: 150 VDC
Output Current: 5 mA DC Max.
Regulation: < 0.1%
Efficiency: Doesn’t matter
Isolation from input to output is required.
Please help with suggestion with topology and reference design
Hello circuitkingshivam,
You can use our ACDC selection tool to help you find a device for your needs. AC-DC | MPS | Monolithic Power Systems. Please fill out the requirements that you need as best as possible.
Hi circuitkingshivam.
What you’ve asked for is typically called a flyback converter.
If you’re not experienced in designing such a east I would suggest you consult someone who has.
The voltage you have asked for (150V DC) means you are after a custom transformer, which is rather specialized.
Also consider 85VAC to 265VAC as the input range which will open a larger range of controllers
You might also want to consider a nixi-tube power supply (especially if its a 1 off)
Simon
Hi circuitkingshivam,
Here is our ACDC flyback product family with secondary side regulation, Flyback Controller | Secondary Side Regulation | MPS | Monolithic Power Systems .
You can choose a solution based on your specific requirements. But please note that the minimum input for these devices would be starting at 85Vac.
The datasheets would generally have a typical application circuit which you can use for reference and also check out the design guidelines mentioned.
Thank you for your kind support
Thank you for your support
Thanks for your kind suggestions
