Hello
Is there a way to plot output impedance of modules in MPSmart?
Trying to run AC analysis using the online provided models always fails periodic operating point and i can’t find a way to fix this issue.
Thanks.
Hello
Thanks.
Hello, apologies for the delayed response for this request.
From what I know, I don’t believe that MPSmart is capable of plotting impedances of module. To get this kind of data, you may have better luck using an EVB and running these tests yourself across varying loads.
As for the AC analysis, understood on the POP error. What is the exact part that you are using? What kind parameters do you have?
I would recommend starting with the default MPSmart IC and then making small changes to see where the POP error starts.
Since it has been some time since your initial post, have there been any updates since then? Let us know.
