Hi Tech,
part#EV2696A-Q-00A
Our customer want to know the connection cable that can be used with this development board?
There is a row of heads on the bottom of the board that are connected to the outside. ( Please see attached image.)
An external USB interface is required. Can you give advice? Thanks.
Hello David,
Can you repost your picture? It is not showing up.
Thank you,
Field Applications Engineer
Hi Vinh,
Please see below image.
I just paste image as above, not sure if you see it or not.
If you can’t see it, can you share your email address? I will forward it to you via email.
Thanks.
Hi Vinh,
May I get update on this request?
Thanks.
Hello David,
I apologize for the delay. Please use our EVKT-USBI2C-02 kit with our Virtual Bench Pro 4.0 GUI.
Thank you,
