NTC connection necessary for MP2759?
As the title says, is it necessary to connect the NTC pin? what if i dont want to use that? do i connect it to GND or leave floating?
Hi @e.noordhuis,
Thank you for posting to the MPS Technical Forum. I will get back to you with an answer to your question shortly.
Isabella
Hello, still waiting for the reply :slight_smile:
Hi @e.noordhuis,
Since there are faults that can be triggered at the NTC pin, you will still need to connect resistors to NTC even if you aren’t using it. Use a resistive divider from VCC to NTC, then NTC to GND like the image below. The resistors’ values can both be 1Mohm or larger to satisfy this requirement.
