Hi, team,
can someone please help me to make DC-DC covert with the cheapest IC or solution with below
input volt : 40-65v DC
o/p - 5v , 1-2 Amp
Also actually i wanted to avoid high costs, so I was planning to test AC to Dc supply only. that’s much more general & cost-effective
& i was expecting to support 60V AC too, ultimately this AC to dc circuit, also first converts AC to the same volt DC then step down.
but I tried a lot of ICs & most cheaper Switcher IC is available for AC 85+ volt, but not for below voltage, Please help if someone can help to understand, why most switcher IC only talk about AC only, while ultimately in their datasheet, they all convert AC to DC using bridge rectifier in their reference circuit.
