I need to develop a current pulse generator with the following characteristics (buck converter):
output peak current regulated with steps of 0.5Amps.
output voltage range between 6 to 12 Volts (depending on the load)
Input voltage = 24V nominal
Minimum pulse width = 5 msec
Max pulse width = 300 msec
Duty cycle = 1-10%
I’m thinking of using a Multiphase current controller with a current limit adjustment referenced to GND, to be able to change the value via an MCU (PWM, DAC, or programmable potentiometer).
Any comments or suggestions?
Is there any reference design to take as a reference?
Thank you for answers!
