what would be the best practice for unused LED channels of this and similar multi-channel LED drivers?
I get that I should disable the channel over I2C before setting enable bit, but from hardware point of view should the IC pins be grounded, pulled down/up or is it best to leave them floating?
This is not stated in datasheets.
Thank you,
JM
