Is there a way to disable AAM mode on the MPQ9846 to improve EMI (“forced PWM mode” as called by other manufactures)? The datasheet says pulling SYNC low before turn-on will enable it, but doesn’t mention any details about disabling it. I’d think SYNC to VCC at turn-on would do it, but the datasheet says tie SYNC to GND if not used. Please clarify.
Hello! It is not possible to disable AAM mode for this device. On pg. 9 and 10 of the DS are figures detailing that the device can meet CISPR25 EMI emissions, if implementing EMI filters.
Hello! Please contact MPSNow using the link below and an FAE should be able to assist you directly. Thanks.
