I am using This part: MPQ8875A-AEC1 on my design, Please clarify me 1 question:
I am planing to use MPQ8875A to charge batteries, and it should work in constant current mode for a while. I’ve seen “OCP no response mode” in datasheet: “the converter maintains
switching in the peak/valley current limit unless thermal shutdown is triggered”.
Is this mode stable with input voltage 19V, output 22V and current 2A, for example? Is MPQ8875A abble to work in this mode long time (maybe 1 hour), can MPQ8875A provide constant current mode with gradual voltage change (due to battery charging)?
Thank you!
