Could you provide me the Theta_JC_bot (Junction to Case thermal resistance with heat flow through package bottom) for the MPQ8633GBLE in its QFN-21 (3*4mm) package.
This is a Jedec parameter (intrinsic device parameter) that is different from the Theta_JB given in the datasheet.
Thank you,
Fred.
Hi fautret,
Thanks for your question.
Yes, I am looking into this and will get back to you asap.
Cindy
Hi fautret,
Can you elaborate on the need for Theta JC_BOT? We don’t usually provide or have this value because Theta_JB measures the junction to board thermal resistance, which is the value that matters once the part is soldered onto the PCB.
Cindy
Hi Cindy,
This JEDEC parameter is required for elaborating the thermal model of the device in our thermal simulation tool.
Best regards,
Frederic
Hi Frederic,
In that case, theta-JB might suffice, but let me confirm with our PL team.
Cindy
Hi Frederic,
PL was able to provide θjc_bot = 2.5℃/W.
Cindy
Hi Cindy,
Thank you for your support.
Best regards,
Fred.
