I’m making an LED control board using MPQ7225A driver. And I looked up OTP writing tools to use OTP Memory and found USB2I2C or USB2SPI tools. By the way, MPQ7225A doesn’t have an interface that uses SPI or I2C, so do you need a conversion interface tool?
The MPQ7225A uses CAN bus. You can convert SPI or I2C data into CAN data, so the part is able to receive instruction. I believe there are transceivers you can find for this purpose.
Allison
