Hi MPS team,
We are planning to use MPQ4272GVE-0000-AEC1 in our design with a quantity of 7 no’s.
We are planning to connect MPQ4272GVE-0000-AEC1 qty 7 no’s in same I2C bus to control the out put voltage.
We are planning to use I2C communication with frequency of 400Khz.
Can you clarify following our queries.
- As all 7 ICs connected on same I2C Channel, we are going to change slave address of each of MPQ4272 using I2C through SW during startup and this will be done only once. Do that address remain same even after a power cycle or we need to do this slave addressing procedure after every power on reset of this device?
- Is there any way to permanently assign different slave address for individual devices.
Thanks & Regards,
Shankar Chavan
