MPQ4242B D+ / D- Lines
I am trying to find out what to do with the D+ and D- lines if I am not planning on connecting them to the IC; they will be connected to another communications device instead.
Should the pins at the IC be left floating, pulled-up, or pulled-down?
Thanks in Advance,
Understood you aren’t using the DP and DM lines. Would that mean that you would be using the CC1 and CC2 lines on the MPQ4242B?
In any case, you should be ok with leaving these pins floating if they will be linked to another communications device.
