MPQ4242 OTP programming
I’m trying to program the MPQ4242 using a separate microprocessor which has I2C. I can read and write to it, however the trouble I run into is getting the clock to run and checking that it’s on. I can bypass this by plugging in a sink device but I’d like to be able to do it with coding.
I’m also at a roadblock for actually confirming the configurations, register 0x2F in the datasheet says a password is required. Can anyone share the password and how to use it? Do you do a separate write before doing the confirmation?
Hi Abraham,
Just got an update on this email from one of our sales, I will be following up on that via email to you. Apologies for the delay in getting back to you, I am working to draft a response to you.
Thank you for the patience.
Adhish
