We’re using the MPQ4242BGVE-0000-AEC1 with the EVQ4242B-VE-00A to build a USB-PD test setup, and we’d like to commit our register config to OTP in-house (via a USB-to-I²C bridge running our own scripts).
The datasheet description of OTP_PROGRAM (bit 7 of CTL_SYS18, 0x2F) says:
A password is required before using the OTP.
But the password itself isn’t described anywhere we can find. Could you share:
The unlock sequence before setting OTP_PROGRAM = 1.
Confirmation of VIN during the burn — IC datasheet says 12 V, EVK datasheet says 13.5 V.
Please fill out the MPS NOW Technical Support form. A member from the MPS NOW team will contact you within 24–36 hours about this request. Contact MPS - Contact
I placed a support ticket about 6 days ago with no response yet, so thought I would make a post in the forum as well. Let me know if I should open a new ticket.
