I have some questions from Optimized Backlight Display Design with the MPQ3367 Efficiency Dpwm=100% E-boost=94.16%, △T/°C=45~50.
- Does the test verify data is from EVQ3367-R-01A ?
2.The EVB PCB is two-layer or four-layer?
3.What is θja and θjc in this EVB?
4.△T/°C=45~50 is mean if Ta=25°C, the IC top case temperature is 25+45~50=70~75°C ? or 70~75°C is junction temperature? - How to calculate IC junction and IC top case temperature in different Pout, could you please explain in this case Dpwm=100% E-boost=94.16%, △T/°C=45~50. ?
Thanks!
