The Application section in the datasheet of the MPQ2013A says that both the input capacitor and the output capacitor should be in the range 1 uF to 10 uF. Does this describe the nominal capacitor value or the effective capacitance taking DC-bias into account?
The output capacitor section describe nominal capacitor value.
Kind Regards,
Nouman
Thank you Nouman for your answer.
Does this also apply to the input capacitor section?
That is correct, yes - X5R or X7R dielectric type ceramic cap in the range of 1-10uF.
Nouman
