MPM82504- VOUT issue
We are using MPM82504 regulator with 4 channels paralleled configuration. The device is detected in Virtual bench Pro 4.0 and we are able to program the device as well. Once after programming, we are not able to get the output (VOUT) even though the enable signal (3.3V) is provided to the CTRL pins.
Hello Dinesh,
How are the CTRL pins connected? What is the status of the PG pins?
Yu
Hi Yu,
I am Buvaneshwaran from Dinesh team.
We are controlling the CTRL pin using the Power sequencer. In contrast, Ctrl pins are high, Without VOut. PG pins are in high state.
Thanks
J.C.Buvaneshwaran
Hi Buvaneshwaran,
Thank you for your patience.
Would you be able to provide the schematic?
Which faults are detected on GUI if there are any.
Yu
