I am trying to set the output voltages on the MPM82504 through the external voltage divider to 0.85V. When I plug in the values calculated in the datasheet and then run the similaion the voltages don’t match. I get 0.72V. What needs to be set in the similation to get the correct output voltages?
Hi Karl,
You should be able to set with IC device parameter setting and changing the external resistors. For 0.85V, the recommended resistor values are 1k for upper and 2.4k lower. Recommend checking the device parameters as well.
Yu
