1.How to select RT resistor value in feedback ?
2.For EMI filter at input side how to select Ferrite bead value and current for same?
3.For EMI filter at input side how to select inductor value and current for same?
In the datasheet, on pg 17 - table 1 gives an RT values with respect to the LED current.
0.1uF and 1uF high freq caps are to be used and to be placed close to IC pins for best performance.
The EMI filter design is done based on the frequency range of the unwanted signals.
Please refer the datasheet and it’s typical application for more details.
Please let us know if you further questions.
Thanks
Saurabh
