MPM6010 evaluation board
Good morning
The MPM6010 can work with one led load ( 3V or 6V ) ?
There is a evaluation board for trial?
Yes, the MPM6010 can work with one 3V/6V LED load.
We do have a eval board. The part number is EVM6010-QV-00A. If you have any problems to get the EVB, please fill out the MPS NOW Technical Support form. A member from the MPS NOW team will contact you within 24–36 hours about this request. Contact MPS - Contact
Fox
Hi
The EN/PWM pin command device :
PWM from 100Hz to 2KHz
EN only for ON/OFF or are possible dimmer current out with analog voltage ?
