MPM54524: Default power sequence
As I read the datasheet it seems that there are no power sequencing per default. All four supplies ramp up at the same time with the same voltage.
So if I want to have some specific ramp sequence and output voltage for each supply, I would need to either set it with I2C and if I dont want to use this, order the device with a specific prefix?
Thank you.
Hi Thomas,
Yes you are correct. The startup sequencing can be configured with either I2C or ordering a specific suffix.
On this note, MPS offers an I2C dongle, in conjunction with Virtual Bench Pro, for quick programming of this component.
Tyler
