Hi Team
We are using MPM5452 in one of out application, with all 4 channal , in current sharing mode . Our observation is we are increasing load current . Output volatge is decreasing (both load current and volatge Read from Active ELB ) . Please do let me know following
If this behaviour is expected
Does output voaltage varies depends on drrop voltage and which eventaully depends of load current. VOUTx = VREFx - VDROOP
2)Can we change output voltage in run time
How i can read load current and voltage ?
Can you let us know how passive current balancing will work here , request you please share some applaication note .
Yes, it depends on the load current as per the relation Vout = Vref - Vdroop.
Whether you can change the output voltage during run time depends on whether you’re using the internal divider to set the output voltage or an external divider to set it.
Hi Vingesh
Can you please share your e mail for sharing schematic .
Complete part no is MPM54524GCQ-0029Z
Regarding droop volatge ,while calculating (droop volatge what should be my Iout ie
Iout= load current or Iout =Load current/ 4 (ie no of o/p shared).
