Is it possible connect the feedbacks directly to outputs without external resistor dividers for MPM54304GMN-0001 as in case of version with 0000 suffix and set the output voltages via I2C adjusting internal references and 2R/R dividers?
In the datasheet on page 42 the only 0000 version has Output Voltage Set Method: I2C, other versions 000x have Output Voltage Set Method: External divider.
Nobody responds this question so I answer myself. We tested parts with suffix and 0001 and it has fully programmable Vout and it si replaceable with 0000 version. There is probably difference in manufacturing default settings only.
