MPM54304 I2C interface connection
I am using the MPM54304 power module in a design and do not plan to use the I²C interface (SCL/SDA). The device will be configured using MTP / default settings only.
Could you please confirm whether the SCL and SDA pins can be left unconnected, or if they should be pulled high or low when the I²C bus is not used?
Thank you for your support.
Best regards,
Paul
Hi Paul,
The SCL and SDA pins can be left unconnected. Please let me know if you have any other questions.
Fox
Hi Fox,
Thanks for your reply.
Best regards,
Paul
