hi,
In MPM54304-0003 this suffix mode, its configuration as table 9 and table 10. It needs external resistor divider to set the output voltage for channel 1, channel 2 and Channel 3/4, right?
I am confused that in this reference design. The chip is MPM54304-0001. Suffix 0001 also configure this chip to work in external resistor divider mode. Yet, the reference design does not have external resistors.
So, my question is: Are external resistor divider needed for set voltages for out1, out2 and out3/4 when using MPM54304-0003?
Thank you.
