Page 18 of the MPM3860 datasheet shows all 3 example circuits to have the same values for setting the output voltage. I assume this is an error and I will use the formula on page 16 to calculate my resistor values?
My desired output voltage is 0.9V for an FPGA core and I will use 19.6K for R1 and 39.2K for R2 per the formula.
Hello dcole5,
Thank you for catching that error.
The values you have selected for 0.9Vout, are correct. Please proceed with them.
