Can I connect MPM3695-10 CTRL pin to VCC pin with pull up resistor?
Hi Harsh,
Yes, that should be fine. Be sure to check the current limit of the CTRL pin to ensure it doesn’t exceed.
However, it is not recommended to connect CTRL pin to VCC due to the rise time delay which could potentially cause problems. It is advised to have CTRL operate independently and not rely on the converter to turn on. CTRL can be connected to an external source or Vin with a resistive divider.
Yu
