the MPM3690-30A datasheet calls out JEDEC MO-275A, however the letter indexing on the “package reference” page 3 and the package information on page 24, is inverted from the JEDEC MO-275A standard. Is the datasheet pin indexing correct, or is JEDEC MO-275A letter pin indexing correct?
Hi Liam,
The letter indexing of pins in device datasheet are similar to the standard of MO-275. I can see how page 3 can be confusing at first glance. Page 3 is marked as “Top View” ,
Page 24 indicates “Bottom View”, and its pin indexing is correct, recommend referencing to page 24 of datasheet to avoid mix-ups.
Kind Regards,
Nouman
