MPM3683-10 - OCP Operation
Hi Team,
Kindly explain in detail regarding the over-current (OC) condition for 31 consecutive cycles.
If possible, share any Graphical representation also.
You are referring to this portion of the datasheet, correct?
When an OC condition is detected for 31 consecutive cycles, then the MPM3683-10 enters hiccup mode. This is what happens when hiccup mode is enabled:
Are there any questions specifically on hiccup mode specifically?
what determines a cycle?
I believe when the text here refers to a cycle, this actually translates to the full period cycle relative to the switching frequency being used for the MPM3683-10.
This of course would depend entirely on how the MODE pin is being set up with respect to the following table:
