Hello i am using the MPM3682 to generate a system 3.3V
I am seeing the the device is heating up, just was wondering if there is some error in the design
Please can you check attached schematics?
Many thanks in advance
Hello guitta,
I just wanted to let you know that this is a part that is not recommended for new design. The newer alternative is the MPM3683-10.
I took a look at your schematic and can see a few differences.
For your trim portion use the equations specified in the datasheet.
When laying out your board follow these recommendations as well.
How hot is too hot in your mind?
actually device is warm - probably also due to neighbour hotter components
just to give some numbers:
Vin = 12V
Vout = 3.3V
Iout[measured] = 2.66Amps ( system idle…]
Tambient: 24°C
Tcase: about 39°C
