I’m considering using the MPM3650 for a 3.3V input voltage, but there are no performance curves under that condition in the datasheet. Output voltage is 0.9V to 1.2V.
Is this component recommended to be used at such input voltage? If yes, could you provide the performance curve under that condition? I’m particularly in the efficiency and thermal derating curves.
Best regards.
