Hi, I have noticed that when I increase the load on the MPM3630 to 4 or 5 amps to trigger the overcurrent protection it just decreases the output voltage and holds a steady current of about 1.5 amps. Afterwards the only way to make it restart the output is to decrease the load to 1.2amps then the voltage will recover. Shouldn’t the controller try to restart periodically with a certain time interval?
The input voltage is 5.1volts the output 3.5voilts.
