I would like to know if the Vcc output of the MPM3510A is dependent or not of the EN pin. I mean, if, once the input has got over the threshold level, the 5V output is available eventhough the enable pin is not asserted.
According to the functional block, it seems that the enable signal affects to the internal 5V regulator, but as I have not find an explicit mention to it, I would like to be sure.
Thank you and regards,
Egoitz.
