Hello MPS Team, I am currently working on a BMS design using the MPF42791 Fuel Gauge IC. I can successfully connect to the device via the GUI and see/load the built-in battery cell models available in the library.
However, I could not find any pre-existing cell models for high-capacity 304Ah or 314Ah cells (e.g., 3.2V LiFePO4 prismatic cells) in the GUI list.
Could you please guide me on how I can obtain the mathematical cell models for 304Ah and 314Ah cells? If these models are not available in the standard library, is there an official tool, characterization procedure, or parameter submission process through MPS to generate a custom cell model for the MPF42791?
Here are the basic specifications of the cells I am planning to use (optional details):
- Chemistry: [LiFePO4]
- Capacity: [304Ah / 314Ah]
- Cell Manufacturer / Part Number: [EVE LF304 / EVE MB31]
Thank you in advance for your support.
Best regards,
