Could you please confirm whether it is possible to connect multiple MPC16253-X-54-2500 modules in parallel on a single output while maintaining active current sharing?
If supported, could you please clarify:
What is the maximum number of modules that can be connected in parallel?
Is active current sharing managed autonomously between modules, or does it require an external controller or additional circuitry?
Are there any limitations or specific design recommendations regarding parallel operation?
Can each module still be individually monitored and controlled via PMBus when operating in parallel?
Thank you for your help.
Best regards,
