datasheet of MP9841 says that Pin 3 and Pin 10 are connected to SW (switch node).
In the recommended layout of the datasheet and in the layout of the evaluation board, the second SW Pin (Pin 3) is left floating in the layout, but connected to SW in the schematic.
Is it recommended to left Pin 3 floating?
Hi clemens.zintgraf,
SW is most likely connected internally in the part. You can test this using a multimeter. If it’s internally connected, you can leave pin 3 floating.
Cindy
Thanks for your answer.
btw, is there a roadmap when MP9841 will be available in DCDCDesigner Tool?
Unfortunately, we don’t have that information.
