The MP8862 buck-boost converter can be enabled/disabled using either the hardware EN pin or the software EN bit in the CTL1 register.
If the part is disabled using the software EN bit, will the current draw be 1mA typical as described in the Supply current (quiescent) parameter? Or will it be 3uA max as described in the Supply current (shutdown) parameter?
Thanks for your help.
