The MP8110 datasheet references gain but does not state a maximum - is there a maximum gain that can be set for the unit and still work?
KM
KM
Hello @kmoua,
Welcome to MPS forums. The MP8110 datasheet recommends using the gain as 10 V/V to achieve the required Vout under different load currents and current sense resistors.
While there’s isn’t a maximum gain mentioned, I would recommend adjusting the current sense resistor (Rs) to achieve the desired output voltage. Note: Vout1 should not exceed 5 V.
