Hi, I’d like to confirm how to handle the PG signal if I use an external clock connected to the SYNC pin for synchronization. Should PG still be connected directly to SYNC in that case?
Connect PG to EN/SYNC to set automatic start-up mode after power is applied. (Refer to pin description as well as page 18 in datasheet)
Yu
Thanks, Yu. So this function will still work if the SYNC pin is being driven by an external clock, correct?
Yes, that is correct.
Yu
